								|  | forum.optyczne.pl
 |  |  Cyfrowe lustrzanki - Field Test: Sony Alpha DSLR-A700 - po ang. + fotki + specyf.
 5kbFlashMemory - Czw 06 Wrz, 2007
 Temat postu: Field Test: Sony Alpha DSLR-A700 - po ang. + fotki + specyf.
 http://www.popphoto.com/c...-dslr-a700.html
 Co myślicie o tych przykładowych fotkach ?
 Dodali parametry techniczne:
 Specifications
 Sony Unveils Alpha DSLR-A700
 System
 Camera type: Digital SLR camera with built-in flash and interchangeable lenses
 Lens mount: Sony Alpha mount; compatible with Minolta A-type bayonet mount
 Lens compatibility: All Sony lenses and Konica Minolta Alpha / MAXXUM / DYNAX lenses
 Image Capture
 Image sensor type: CMOS
 Image sensor size: 23.5 x 15.6 mm (APS-C type)
 Total pixel number: Approx. 13,053,000 pixels
 Effective pixel number: Approx. 12,246,000 pixels
 Anti-Dust system: Charge protection coating on low pass filter and Image-sensor shift mechanism
 Recording
 Media: Memory Stick: Memory Stick Duo, Memory Stick PRO Duo, Memory Stick PRO-HG Duo
 Slot: Dual slot for Memory Stick Duo / CompactFlash
 File system: FAT 12, 16, 32
 Image format: JPEG, RAW (ARW 2.0 format), RAW + JPEG
 Image size: RAW: 4288 x 2856, L (12M, 3:2); 4272 x 2848, M (6.4M, 3:2): 3104 x 2064, S (3.0M, 3:2): 2128 x 1424
 Color space: sRGB, Adobe RGB
 Noise reduction:
 Long Exp. NR: On/Off, available at shutter speeds longer than 1 sec.
 High ISO NR: High / Normal / Low, available at ISO 1600 or higher
 Creative Style:
 Base Styles: Standard, Vivid, Neutral, Adobe RGB
 User setting registration: 3 style boxes; Standard, Vivid, Neutral, Adobe RGB, Clear, Deep, Light, Portrait, Landscape, Sunset, Night view, Autumn leaves, B/W, Sepia
 Adjustable Items: Contrast (-3 to +3 steps), Saturation (-3 to +3 steps), Sharpness (-3 to +3 steps), Brightness (-3 to +3 steps), Zone Matching (-1 to +2 steps)
 D-Range Optimizer:
 Mode: Off, Standard / Advanced: Auto / Advanced: Level
 Advanced Level setting: 5 levels
 DRO advanced bracketing: 3 frames, H/L selectable
 White Balance
 Mode: Auto, Daylight, Shade, Cloudy, Tungsten, Fluorescent, Flash, Color Temperature / Color filter, Custom
 Color temperature: 2500 - 9900 k with 19-step Magenta / Green compensation
 White balance bracketing: 3 frames, H/L selectable
 Super SteadyShot
 System: Image-sensor shift mechanism
 Capability: Approx. 2.5 EV - 4 EV decrease in shutter speed (varies according to shooting conditions and lens used)
 Viewfinder
 Type: Fixed eye-level system with optical glass type pentaprism
 Field of view: 95%
 Magnifiation: 0.9 x, with 50mm lens at infinity
 Eye relief: Approx. 25 mm from the eyepiece, Approx. 21 mm from the eyepiece frame at -1 diopter
 Diopter adjustment: -3.0 to +1.0 m-1
 Focusing screen: Spherical Acute Matte
 Auto Focus System
 No. of focus points: 11 points
 Sensitivity range: 0 EV to +18 EV (at ISO 100 equivalent)
 Focus mode: Single-shot AF, Automatic AF, Continuous AF, Direct Manual Focus, Manual Focus
 Focus area: Wide focus area (Auto,11 areas), Spot focus area, Local focus area (11 local areas, selection with the multi-selector)
 Eye-Start AF system: On/Off selectable
 Auto Focus System
 Light metering:
 Type: TTL metering
 Cell: 40-segment honeycomb-pattern SPC
 Range: 0 EV to 20 EV (+2 EV to +20 EV with Spot metering) (at ISO 100 equivalent with F1.4 lens)
 Mode: Multi segment, Spot, Center weighted
 Exposure setting: Auto, Program AUTO (with Program Shift), Shutter priority, Aperture priority, Manual, Scene selection (Portrait, Landscape, Macro, Sports action, Sunset, Night view/portrait)
 Exposure compensation: +/-3.0 EV, 0.3 EV / 0.5 EV steps selectable
 AE bracketing: Bracket: Cont. / Bracket: Single, with 0.3 / 0.5 / 0.7 EV increments, 3/5 frames selectable
 ISO sensitivity (REI): AUTO: ISO 200 - 1600 (lower limit / upper limit selectable)
 ISO range: ISO100 - 3200 equivalent (Up to ISO 6400 can be set as expanded ISO range)
 ISO steps: 1/3 EV step
 Auto Focus System
 Built-in flash system: Manual popup; approx. GN 12 (in meters at ISO 100); coverage of up to 16 mm (in the focal length); approx. 3 sec. recycling time; flash-ready indicator
 Flash metering system: ADI flash / Pre-flash TTL / Manual flash
 Flash mode: Autoflash, Fill-flash, Rear sync, Slow sync, Manual flash
 Flash compensation: Red-eye reduction, High speed sync (with external flash) +/- 3.0 EV (0.3 / 0.5 EV steps selectable)
 Flash bracketing: 3/5 frames, 0.3 / 0.5 / 0.7 EV steps selectable
 Shutter
 Type: Electronically-controlled, vertical-traverse, focal-plane type
 Speed range: 1/8000 sec. - 30 sec., bulb
 Flash sync speed: 1/250 sec. (Super SteadyShot off), 1/200 sec. (Super SteadyShot on)
 Drive
 Drive mode: Single-frame advance, Continuous advance (H/L selectable), Self-timer (10 sec. / 2 sec. delay, with mirror-up function)
 Continuous advance rate: Hi: approx. 5 frames/sec. max., Lo: approx.3 frames/sec.
 No. of frames recordable w/ continuous advance: JPEG (Extra fine): 8, RAW: 17, cRAW (compressed): 24,RAW+JPEG: 11 cRAW+JPEG:12, JPEG (Standard / Fine): No limit (until the memory card is full)
 Camera Function
 Depth-of-field preview: Yes (by pressing Depth-of-field preview button)
 Auto review: 10 sec. / 5 sec. / 2 sec. / Off selectable
 LCD Monitor
 LCD screen size: 7.5 cm (3.0 type) TFT
 Total number of dots: 921,600 (640 x 3 (RGB) x 480) dots
 Field of view: 100%
 LCD brightness setting: +/-5 steps
 Print
 Print: function Exif Print, Print Image Matching III, PictBridge, DPOF setting
 Interface
 HDMI Out: HDMI type C minijack
 1920 x1080i 59.94/50 Hz, 1280 x 720p 59.94/50Hz, 720 x 480p 59.94 Hz, 720 x 576p 50 Hz
 USB Out: SB2.0 (Hi-Speed), USB Connecting (Mass Storage, PTP, Multi LUN)
 Sync. terminal: Adaptable to the sync. terminal of the opposite polarity
 Video Out: NTSC / PAL selectable (in Menu)
 Remote Control
 Wired: With optional RM-S1AM or RM-L1AM
 Wireless: With RMT-DSLR1
 PC control: Image data transfer and camera control with supplied software
 Power
 Power source:
 Battery: Solely with the Recheageable Battery Back NP-FM500H (7.2 V)
 AC adapter: AC-VQ900AM (optional) (7.6 V)
 Battery charger: BC-VM10
 Battery life: Approx. 650 shots (CIPA measurement)
 Power saving mode: Shut down after 1 / 3 / 5 / 10 / 30 min
 Others
 Dimension (WxHxD): Approx. 141.7 x 104.8 x 79.7 mm (excl. protrusions)
 Weight: Approx. 690 g (w/o batteries, memory card, body accessories)
