Lampy błyskowe i oświetlenie - LED Light Cube
dcs - Sro 29 Paź, 2014 Temat postu: LED Light Cube The IC12 Led Light Cube Features:
Continuous high speed flashing at full power
High capacity – over 1000 flashes from a single battery charged to full power
300 watts (f22 @ 1 metre / 100 ISO)
SProduct Features
Portable LED lighting
5,000 lumens of light output / running time 45minutes
Continuous High speed flashing at full power
Battery internally fitted
High Capacity – over 800 flashes @ 1/60th of a second duration from a single battery charge at full power
Over 150 Watts / 5,000 Lumens of light output
Ultimate portable lighting kit – Sold as individual or set of 4 lights
Stackable. Build versatile light banks
Stable colour temperature. Consistent colour temp as power levels are adjusted
Use as a video light. - (Duration to be determined. Estimated 45min from battery charge)
Master control. Set the lighting condition of a single unit in array mode and all others will match the settings.
Modelling light feature.
Trigger remotely via sync cable, wireless trigger or as light sensitive slave
Adjustable flash speed. Adjust the flash speed of the unit to shoot at faster or slower durations. 8000MS – 1 Sec
Noiseless operation - no internal fan, no added noise on film production
Size: 100mm (approx. 4 inches) x 100mm x 100mm
Weight: 0.750kg (approx. 1.65 lbs)
http://www.ledlightcube.com/
http://www.ledlightcube.co.uk/in-the-press/
