Aparaty analogowe - MMOEXP: Arc Raiders provides a lot of opportunities
Ludwighench - Dzisiaj 9:39 Temat postu: MMOEXP: Arc Raiders provides a lot of opportunities ARC Raiders Items provides a lot of opportunities to search its large maps for well-hidden items, often testing your ability to read into vague hints about locations. It can be a lot of fun to track things down on your own, but it can also prove challenging at times. If you're struggling to find Major Aiva's Patch for the Echoes of Victory Ridge quest, we'll help you along with things.
Note that you need to extract from the topside with Major Aiva's Patch once you obtain it. With this in mind, it's a good idea to bring along an augment with a safe pocket so that you can ensure you don't lose your quest item even if you fall in battle. When you're ready to get started, read on for where to find Major Aiva's Patch in Arc Raiders.
Your first objective for Echoes of Victory Ridge will be to actually find Victory Ridge, which is located in the northern portion of the Dam Battlegrounds map. Zoom in and seek the West Broken Bridge POI that's where you're headed. Note that this is a mostly safe area in the majority of matches, but you never know if you might run into other questers, so keep an eye out and try to be friendly. Or shoot them on site it's your call.
When you arrive at the circled area above, you'll need to look for a small box containing Major Aiva's Patch. This can be hard to spot if you don't know where to search. Look around for part of the fallen road that can be crawled under more easily spotted if standing on the northern end of the POI and looking south. Under the right side of this crumbled road is the box with Major Aiva's Patch inside.
Place Major Aiva's Patch in your safe pocket if you came equipped with one, then head east to the North Complex Elevator to extract. There are often a lot of buy ARC Raiders BluePrints patrolling here, so retreat to safety after calling the elevator if you get their attention and can't fight your way out of it. Hopefully, you'll get back to Speranza and turn this quest in so you can move along to the next one.
