Cyfrowe lustrzanki - Pentax K-30
jaad75 - Pon 21 Maj, 2012 Temat postu: Pentax K-30 W sumie to już nie plotka - niemal oficjalnie:
| Cytat: | BrandPENTAX
ModelK-30 Lens Kit (15758)
ColorBlue
Dimensions5.1 x 3.8 x 2.8 in
Weight1.3 lbs.
Package TypeSingle Lens KitImage Sensor
Image SensorCMOS
Image Sensor Size23.7 x 15.7mm (APS-C)
Gross Pixels16.5 MP
Effective Pixels16.3 MP
Dust Cleaning SystemSensor movement w SP coating on low pass filter
Image StabilizationSensor-shift SR
Resolution16M (4928x3264), 12M (4224x2816), 8M (3456x2304), 5M (2688x1792)White Balance
White BalanceImage sensor detection w light wavelength sensor assistViewfinder
Viewfinder TypePentaprism
Coverage100%
Magnification0.92X (w 50mm F1.4 at infinity)
Dioptric Adjustment-2.5m to 1.5m
Focusing ScreenNatural-Bright-Matte III (interchangeable)
Depth-of-Field PreviewOptical (diaphragm stop-down), digitalLCD Monitor
LCD3.0" 921k
Brightness AdjustmentYesFocus
Focus TypeSAFOX IXi+ TTL phase-detection 11 point (9 cross) wide autofocus system w light wavelength sensor and diffraction lens
Focusing ModesAF.A (auto), AF.S (single, w focus lock, focus/shutter priority selectable), AF.C (continuous, w focus/FPS priority selectable), Manual
AF-assist BeamYes, via dedicated LED AF assist lamp
Focusing Point SelectionAuto 11 pt, Auto 5 pt, User-Selectable (w Expanded Area AF), CenterExposure
Exposure Compensation+/- 5 EV (1/3 and 1/2 steps)
Metering SystemTTL open aperture 77 segment metering
ISO SensitivityAuto: 100-12800 (1/1, 1/2, 1/3 steps), expandable to 100-25600, auto range selectable
Manual: 100-12800 (1/1, 1/2, 1/3 steps), expandable to 100-25600Shutter
Shutter TypeElectronically controlled, vertical-run, focal plane shutter
Shutter Speed1/6000 to 30 sec (1/3 or 1/2 steps), Bulb
Self-timer12s, 2sFlash
Flash TypeRetractable P-TTL popup flash
Flash ModeOn, Redeye, Slow Sync, Slow Sync + Redeye, Trailing Curtain Sync, Wireless
Flash Range28mm wide angle equivalent
Flash Exposure Compensation-2 to 1 EV
External FlashHotshoe (P-TTL), high speed sync and wireless w PENTAX dedicated flashDrive System
Drive ModesSingle, Continuous (Hi, Lo), Self-Timer (12s, 2s), Remote (0s, 3s), Auto Bracketing (3 frames)Function
Scene ModesPortrait, Landscape, Macro, Moving Object, Night Scene Portrait, Sunset, Blue Sky, Forest, Night Scene, Night Scene HDR (JPG), Night Snap, Food, Pet, Kids, Surf & Snow, Backlight Silhouette, Candlelight, Stage Lighting, Museum
Live View FunctionMagnification (2-6X), Grid Overlay (4x4, Golden Ratio, Scale), Bright/Dark Indication, Histogram
PlaybackOne Shot (no data, basic data, full data, color channel histogram, bright/dark indication, copyright info), Multi Image Display (4, 9, 16, 36, 81 thumbnails), Magnification (up to 16X, scrollable, quick magnification), Image Rotation, Calendar Filmstrip, Display, Folder, Slideshow, Select & Delete, Movie Playback (no data, basic data, full data), Save RAW Data From JPG (if available in buffer memory)Recording System
File FormatRAW (DNG), JPG (EXIF 2.3), DCF 2.0 compliant, DPOF, PIM III
Color SpacesRGB, AdobeRGB
Recording MediaSD / SDHC /SDXC CardMovie
Movie FormatMOV MPEG-4 AVC (h.264)
Movie Recording1920x1080p30/25/24, 1280x720p60/50/30/25/24, 640x480p30/25/24
Max. Recording Resolution1920 x 1080Lens
Compatible LensesPENTAX KAF3, KAF2, KAF, and KA (K mount, 35mm screwmount, 645/67 med format lenses useable w adapter and/or restrictions)
Lens MountPENTAX KAF2 bayonet stainless steel mountInterface
USBUSB 2.0 hi-speed
A/V OutYes
MicBuilt-in monauralPower Source
BatteryRechargeable Li-Ion battery D-LI109 (included), AA battery holder D-BH109 for 4 AA batteries (sold separately)Feature
FeaturesHigh performance 16 megapixel APS-C CMOS image sensor.
Full weather sealing for worry-free use in any weather condition.
Rugged coldproof design for sub-freezing use (-10C, 14F).
PRIME M image processing engine, optimized for video, also captures outstanding still images.
Full 1080p30 HD video features h.264 compression, flexible exposure control, and HDR finishing options.
Advanced SAFOX IXi+ autofocus engine features AF assist lamp, light source sensor, and improved optical components.
Large 3 inch LCD is wide angle viewable, and features 921,000 dots of resolution.
Live View focus peaking highlights in-focus surfaces for fast and accurate manual or autofocus.
Low profile glass pentaprism viewfinder achieves a 100% optical field of view.
Highly accurate 77 segment metering system for accurate exposure, even in complex lighting.
Fast 6 FPS continuous shooting mode and 1/6000 second maximum shutter speed.
ISO speeds up to 25600 improve shutter speeds while minimizing noise in low lighting.
Programmable front and rear e-dials for convenience and PENTAX Hyper shift operation.
Sensor-shift Shake/Dust Reduction ensures sharp, dust-free imaging with any mounted lens.
Traditional modes combine with automatic modes for powerful, user-friendly operation.
In-camera HDR shooting modes feature multiple blending options and pixel alignment.
Compatible with both rechargeable Li-Ion and AA batteries (via optional AA battery holder).
Highly compact yet durable body with comfortable
From PentaxForums.com: http://www.pentaxforums.c...l#ixzz1vXC0zyzL
| Cytat: | Major Features of PENTAX K-30
1. High-resolution, low-noise, true-to-life image reproduction
The K-30 incorporates the latest CMOS image sensor with a large image-capturing area measuring 23.7mm by 15.7mm. It assures high-speed image data readout to deliver super-high-resolution, rich-gradation digital images with 16.28 effective megapixels. This image sensor is coupled in the K-30 with the PRIME M imaging engine for the recording of high-quality, full HD movie clips (1920 x 1080 pixels, 30 frames per second). The camera also minimizes luminance noise at low sensitivities, while offering a wide sensitivity range between ISO 100 and ISO 12800 (or even ISO 25600 when expanded via a custom function).
2. Sporty, functional design perfect for outdoor shooting
Thanks to the 81 seals set in its compact, lightweight, portable body, the K-30 is built to be weather-resistant, dustproof and cold-resistant, as well as proven functionality in temperature as low as -10°C. This means that the K-30 can be taken along on outdoor activities such as camping and mountain climbing, for the joy of high-quality digital SLR photography without worrying about weather conditions. Its exterior has been designed to be both sporty and functional for active outdoor shooting: a large grip for a firm, secure hold of the camera; a low-profile pentaprism housing for reduced height; and a rounded, soft-rubber casing for firm hold of the camera during vertical-position shooting.
3. Optical finder with nearly 100% field of view
Despite its compact body that is smaller and lighter than conventional mid-level models, the K-30 comes equipped with a glass prism finder with nearly 100% field of view and approximately 0.92-times maximum magnification (with a 50mm f/1.4 lens at infinity) to cover the entire field of view for easy focusing and framing. Since it delivers a clear view of the subject even in bright sunshine and eliminates parallax and time lag in the viewfinder image, the K-30 responds efficiently and reliably to demanding applications and subjects, such as landscapes requiring delicate, high-precision framing, and sports scenes where the timing of shutter release is critical. The K-30 accepts a PENTAX-original Natural-Bright-Matte III focusing screen to facilitate manual-focusing operation. The photographer can replace the standard focusing screen with one of the available optional screens, including cross-lined and scale types, to accommodate more specialized applications.
4. Newly developed SAFOX IXi+ AF module for improved autofocus performance
The K-30 features the state-of-the-art SAFOX IXi+ AF sensor module, which assures responsive, high-precision autofocus operation by incorporating a diffraction lens to minimize chromatic aberration in accordance to the characteristics of each individual lens. It also factors the light source at the time of shooting into its calculations. Nine of its 11 sensor points have cross-type sensors to capture all kinds of subjects in sharp focus, while its spotbeam projector assists the AF system at poorly lit locations. The K-30’s AF algorithm has also been upgraded in all areas. A new select-area expansion function allows the sensor module to continue to track a moving subject, even when it moves out of a pre-assigned auto-tracking area, by assessing distance data collected by neighboring focus sensors. The accuracy and speed of detecting moving subjects during autofocus shooting, and autofocusing performance when using a telephoto lens, have been greatly improved as well.
5. High-speed burst shooting at approximately six images per second
When shooting sports, stage performances or wildlife, the K-30’s high-speed burst shooting function comes in handy, as it allows the photographer to record active, fast-moving subjects in a series of images — at a maximum speed of six images per second (in the JPEG recording format).
6. Advanced Live View shooting with helpful features
Thanks to the latest CMOS image sensor and upgraded algorithm, the K-30 offers a clear, true-to-life Live-View image (at 60 frames per second). It also features a focus-assist function to improve manual-focusing accuracy, as well as a choice of three grid display patterns including Golden Section.
7. Effortless, user-friendly Auto Picture and Scene modes
The K-30 features the PENTAX-original Auto Picture mode, which automatically selects the most appropriate shooting mode for a given subject or scene from Portrait, Landscape, Macro and other distinctive shooting modes. The photographer can concentrate on image composition and shutter opportunity, while leaving all other camera settings to the K-30, including shutter speed, aperture, white balance, saturation, contrast and sharpness. The K-30 also offers 19 Scene modes — including Night Scene Portrait, Pet and Backlight Silhouette — to simplify the photographing of subjects and scenes too complicated or too demanding for inexperienced digital SLR photographers, by optimizing all camera settings with a simple choice of the corresponding icon on the camera’s LCD monitor.
8. PENTAX-original SR mechanism with user-assisting options
The K-30 features the PENTAX-developed SR (Shake Reduction) mechanism, which effectively reduces camera shake for sharp, blur-free images even under demanding shooting conditions — such as when using a telephoto lens, shooting in the dark or at night without supplementary flash illumination. This innovative mechanism works with almost all PENTAX interchangeable lenses — even those developed for film-format cameras.* Thanks to the SR mechanism’s flexible design that tilts the image sensor unit in all directions, the K-30 offers several useful features to assist the photographer during shooting, including: an Automatic Horizon Correction function to assure high-precision image framing and effortless adjustment of horizontal alignment; a Composition Adjustment function to allow minute adjustment of image alignment horizontally, vertically and axially; and an ASTROTRACER mode, to simplify astronomical photography in combination with the optional O-GPS1 GPS Unit.
* Lenses compatible with this mechanism: PENTAX K-, KA-, KAF-, KAF2- and KAF3-mount lenses; screw-mount lenses (with an adapter); and 645- and 67-system lenses (with an adapter). Some functions may not be available with certain lenses.
9. A selection of image-processing tools for creative, personalized expression
The K-30 features the custom image function, which allows the user to easily and quickly select the desired finishing touch for a particular image, with a choice of 11 custom images, including Bleach Bypass to create a dramatic visual effect used in motion pictures, and Cross Process to produce a fanciful, eye-catching image with dramatic colors. It also offers a choice of 19 distinctive digital filters, including Miniature, which transforms an actual scene into what appears to be an image of miniature models. These filters add distinctive visual effects to captured images and produce creative, artistic images without the need for a computer. The user can further expand the creative possibilities by applying multiple filters to a single image.
10. Choice of two power sources
In addition to the standard lithium-ion battery capable of capturing approximately 480 images with a single recharge,** the K-30 can also be powered by four AA-size batteries using the optional D-BH109 AA-Battery Holder. Since AA-size batteries can be easily obtained almost anywhere around the world, there’s no worry about battery shortages, even when on the road.
** Under testing conditions prescribed by PENTAX, using the D-LI109 Rechargeable Lithium-ion Battery with no flash discharges.
11. Other features
I. Large, wide-view 3.0-inch LCD monitor with approximately 921,000 dots
II. 77-segment multi-pattern metering system for extra-accurate light measurement
III. DR (Dust Removal) mechanism to shake dust off from the surface of the CMOS image sensor
IV. PENTAX-designed Hyper control system to assure flexible, unfailing response to the photographer’s creative intentions
V. Dynamic-range expansion function to compensate for both whitewashed (overexposed) and blacked out (underexposed) areas
VI. RAW-date filing of a just-recorded JPEG-format image
VII. RAW/Fx button for single-action switching of image file format, as well as for assignment and instant recall of a specific function
VIII. SILKYPIX Developer Studio 3.0 for PENTAX (RAW-data processing engine developed by Ichikawa Soft Laboratory) included, in support of the K-30’s in-body RAW data processing capability
From PentaxForums.com: http://www.pentaxforums.c...l#ixzz1vXCDrg14
[ Dodano: Pon 21 Maj, 2012 21:34 ]
I jeszcze porównanie wymiarów z K-5:
dcs - Pon 21 Maj, 2012
Dzięki Ci Pentaksie za Pentaprism!
hijax_pl - Pon 21 Maj, 2012
| jaad75 napisał/a: | | I jeszcze porównanie wymiarów z K-5: | Taki młodszy brat K5 zatem Fajnie
Wzornictwo trochę odpustowe, szczególnie w połączeniu z niebieskim korpusem.
Aszex - Pon 21 Maj, 2012
Do jakiego usera jest to adresowane gdyby odnieść do canon lub nikona? C xxx lub N5xxx?
C600 i D5100
Swoją drogą ciekawe jaka cena w PL będzie. To znaczy ile PL znaczy $800?
Aszex,
Na papierze kładzie D5100, 600D, A57.
Do takiego, któremu D7000, 60D, A65 -to za drogo.
[ Dodano: Pon 21 Maj, 2012 21:46 ]
hijax_pl,
Dolar po 4zł?
Hmm, ciekawe co z ceną k5. Teraz jest około 1050-1100 z kitem, a k-r 600-650. Czyli plus minus taka polityka jak u Nikona.
[ Dodano: Pon 21 Maj, 2012 21:48 ]
dcs, a w czym +-?
| dcs napisał/a: | | Wzornictwo trochę odpustowe, szczególnie w połączeniu z niebieskim korpusem. | Po przyzwyczajeniu się nawet zaczął mi się podobać - zwłaszcza czarny i biały.
| hijax_pl napisał/a: | Swoją drogą ciekawe jaka cena w PL będzie. To znaczy ile PL znaczy $800? | To znaczy ~3000, czyli ciut taniej niż teraz za K-5, tyle, że to cena na wejście, więc będzie szybko spadać, a następca K-5 już na horyzoncie...
| dcs napisał/a: | | Na papierze kładzie D5100, 600D, A57. | Pentax zawsze dawał więcej od końkurencji. | dcs napisał/a: | Do takiego, któremu D7000, 60D, A65 -to za drogo.
| A65? No to Nikon już D3200 pokazał tej zabawce miejsce w szeregu | dcs napisał/a: | | Dolar po 4zł? | Byle nie jak przelicznik w empiku
Aszex,
| Aszex napisał/a: | | Hmm, ciekawe co z ceną k5. |
Następca będzie droższy. /jak zwykle/
[ Dodano: Pon 21 Maj, 2012 21:51 ]
| hijax_pl napisał/a: | Byle nie jak przelicznik w empiku |
-Masz na myśli makulaturę?
| hijax_pl napisał/a: | | Pentax zawsze dawał więcej od końkurencji. | Ale tym razem to trochę chyba przesadził...
No chyba, że faktycznie będzie jakiś supertani korpus entry-EL poniżej K-30... Nie do końca wierzę w zastąpienie tego segmentu mirrorlessami...
lotofag - Pon 21 Maj, 2012
Obrazkowo o jego "ficzerach"
Co prawda guzikologia okrojona, ale dwa kółka i pryzmat to jest to
Aszex,
Choćby w wizjerze.
Dziwi mnie brak gibanego wyświetlacza.
[ Dodano: Pon 21 Maj, 2012 21:55 ]
lotofag,
| lotofag napisał/a: | Obrazkowo o jego "ficzerach" |
Mogłeś napisać, może bym zrozumiał.
Chyba, że to do Aszex, to przepraszam.
To chyba trochę podobna filozofia, jaką Nikon zastosował w D7000 - upchnąć jak najwięcej prawdziwych ficzerów fotograficznych w korpusie kierowanym do amatorów-entuzjastów, tyle, że znacząco taniej, niż zrobił to Nikon...
[ Dodano: Pon 21 Maj, 2012 21:56 ]
| dcs napisał/a: | Dziwi mnie brak gibanego wyświetlacza.
| Mnie też, ale pewnie dlatego, że postawili raczej na uszczelnienia...
dcs, jak komuś ciężko przebrnąć przez pierwszy post w tym temacie, to niech sobie chociaż na obrazek zerknie
Niestety obrazek jest typowo marketingowy. Brak na nim np. wspomnianych dwóch kółek, choć z drugiej strony jest pentapryzmat...
| jaad75 napisał/a: | | Mnie też, ale pewnie dlatego, że postawili raczej na uszczelnienia... |
-Dla wielu pstrykaczy będzie to argument na NIE.
| lotofag napisał/a: | dcs, jak komuś ciężko przebrnąć przez pierwszy post w tym temacie, to niech sobie chociaż na obrazek zerknie |
Hmm, manual tak łatwy, że dziecko sobie z nim poradzi? Szykuje się hit sprzedaźy...
Aszex, Ty serio pytasz w czym K-30 wygląda lepiej od innych korpusów z tego segmentu?...
| dcs napisał/a: | | -Dla wielu pstrykaczy będzie to argument na NIE. |
a komu przeszkadza uszczelnienie
Sunders - Pon 21 Maj, 2012
| Aszex napisał/a: | | komu przeszkadza uszczelnienie |
nie uszczelnienie, tylko brak gibanego LCD
jaad75, tzn w czym np jest lepszy np od nikona 5100. Nie znam na pamięć specyfikacji...
| Aszex napisał/a: | w czym np jest lepszy np od nikona 5100. Nie znam na pamięć specyfikacji... |
Zapewne nikt nie zna na pamięc, a porównać samemu nie łaska?
| dcs napisał/a: | | -Dla wielu pstrykaczy będzie to argument na NIE. | Owszem, zwłaszcza z tego segmentu... W Pentaksie zdaje się cały czas wierzą, że ludziom raczej zależy na ficzerach fotograficznych, typu 100% pentapryzmatyczny wizjer, czy dwie rolki, niż odchylany LCD...
| Aszex napisał/a: | | w czym np jest lepszy np od nikona 5100. Nie znam na pamięć specyfikacji... | pryzmatem, dwiema rolkami, 1/6000s, itd...
Aszex,
| Cytat: | a komu przeszkadza uszczelnienie |
-Brak gibanego wyświetlacza.
Ale ci użytkownicy myślą, że czas 6000 to więcej niż 4000.
| Aszex napisał/a: | jaad75, tzn w czym np jest lepszy np od nikona 5100. Nie znam na pamięć specyfikacji... | 2 rolki, wizjer, sterowanie lampami, full manual w video, max szybkość migawki, seria...
| jaad75 napisał/a: |
Zdaje się, że Olympus pokazał, że da się zrobić uszczelniany korpus z gibanym wyświetlaczem - tyle, że nie był to EL
lotofag, zrobiłbym to, ale nie ma go jeszcze w porównywarkach...
| lotofag napisał/a: | Zdaje się, że Olympus pokazał, że da się zrobić uszczelniany korpus z gibanym wyświetlaczem - tyle, że nie był to EL | Ja nie wątpię, że się da, ale wątpię, że tanio...
| Aszex napisał/a: | lotofag, zrobiłbym to, ale nie ma go jeszcze w porównywarkach... |
Ło Jeżu, niedługo to niektórzy się nie będą potrafili nawet zesrać bez odpowiedniej aplikacji
Ciekawe, czy dali mikrokalibrację AF i jaki jest x-sync...
[ Dodano: Pon 21 Maj, 2012 22:21 ]
Jeśli niebieski jest zbyt odpustowy:
[ Dodano: Pon 21 Maj, 2012 22:24 ]
i jeszcze jedno porównanie:
| jaad75 napisał/a: | | Jeśli niebieski jest zbyt odpustowy: |
Mogliby choć troszeczkę skóry, lub lateksu zastosować...
http://tnij.org/qrve
| dcs napisał/a: | | Mogliby choć troszeczkę skóry, lub lateksu zastosować... | że na tylnej ściance?...
Niezły ruch:
-biały dla Japończyków i Arabów z np. Dubaju
-czarny dla domin /od "domina"/ i fetyszystów
-niebieski dla kobiet, dla tych którym się wydaje, że są kobietami i fanów najpopularniejszego gatunku muzyki na Białostocczyźnie.
sigmiarz - Pon 21 Maj, 2012
jednak pryzmat! Canon przechodzi na produkcję lakieru do włosów, nie ma wyjścia
szczególnie przy tym dotykowym ekraniku w 650d.. może jeszcze androida z gestami tam wrzucą..
jaad75,
| jaad75 napisał/a: | | Ciekawe, czy dali mikrokalibrację AF i jaki jest x-sync... |
IMHO będzie jak w K-r tzn. 1/180s i mikrokalibracja AF.
Oficjalnie:
http://www.pentaximaging....ital_SLR_Camera
[ Dodano: Wto 22 Maj, 2012 00:08 ]
I przy okazji nowa budżetowa 50-tka:
http://www.pentaximaging....-Telephoto_Lens
[ Dodano: Wto 22 Maj, 2012 00:10 ]
I DPreview:
http://www.dpreview.com/previews/pentax-k-30/
Już go widzę na półkach po 4000zł z 18-55...
Dlaczego po 4000zł?
Na photorumors było z 18-55 799Euro.
Jest tam teraz cena Panasonic Lumix G Vario 12-35mm f/2.8 -1300$
Startuje z ceną podobną do obecnej ceny K-5, więc z pewnością zdecydowanie bliżej 3000zł.
moronica - Pon 21 Maj, 2012
dcs, przesadzasz, dolar nie kosztuje 4zl a 800eur to nie 4000zl
Całkiem ok wygląda przy K-5, znacznie lepiej, niż K-r, IMHO:
[ Dodano: Wto 22 Maj, 2012 00:35 ]
Dziwne, że focus peaking nie działa w trybie filmowania. Spore niedopatrzenie.
moronica,
Niestety polskie ceny nie są wynikiem prostego przeliczenia po kursie /zajrzyj do np. B&H/.
dcs, dlatego możesz liczyć ceny względem obecnej ceny K-5. Przy K-5 w okolicach 3000, ten aparat nie może być droższy.
[ Dodano: Wto 22 Maj, 2012 00:49 ]
BTW, DA50/1.8 ma kosztować ~$250, czyli nie będzie aż tak tanio jak w np. Canonie...
dcs, ceny w euro rowniez nie sa wynikiem prostego przeliczenia po kursie dolara. jednakze nie widze powodu, by ceny w PLN mialy byc az tak wysokie w stosunku do cen w euro
Obstawiam początkową cenę w PL 3200 zł w kicie z DA-L (co i tak będzie trochę za drogo).
Przesadziłem.
W B&H jest 50$ droższy od K-01.
Ciekawe kto kupi K-01. Tu pentapryzmat, tam...nic.
D5100 z 18-55 jest po 2500zł -ale to nie ta liga.
jaad75 - Wto 22 Maj, 2012
| Cytat: | | D5100 z 18-55 jest po 2500zł -ale to nie ta liga. | Ale D5100 jest już na rynku jakiś czas. K-30 zejdzie do tej ceny zapewne koło świąt.
dcs - Wto 22 Maj, 2012
Nie ma powodu żeby miał w przyszłości kosztować tyle co D5100. Oferuje dużo więcej.
[ Dodano: Wto 22 Maj, 2012 01:18 ]
Choć jak patrzę na ceny w USA, to chyba masz rację.
http://tnij.org/qrxm
Z ostatnich nowości - jest focus peaking w trybie wideo, ale zanim włączymy nagrywanie (czyli trochę lepiej, ale wciąż nie za dobrze), jest kalibracja (chociaż nie wiem jeszcze jakiego typu) i x-sync to 1/180s.
Może wymusi to na Nikonie zrobienie następcy D90 -pozycjonowanego pomiędzy D5100, a D7000.
moronica - Wto 22 Maj, 2012
po co? wsrod korpusow DX maja inna dziure do zalatania a teraz jeszcze ma byc to budzetowe FX, nie beda sie rozmieniac na drobne
moronica,
Czekasz na D400?
jak sie doczekam to wtedy pogadamy
Na emeryturze będziesz miała więcej czasu na fotografowanie.
skoluje sobie chodzik z mocowaniem statywowym
Dlaczego nie D800 crop do ptaków i ff na koncerty i inne?
dwukrotna roznica w cenie
| moronica napisał/a: | | dwukrotna roznica w cenie | Do emerytury zdążysz zarobić...
To jest argument.
Twój mężczyzna nie daje ci prezentów?
tylko czy d90 dotrwa do tego czasu
dcs, ja sie ciesze ze on mi pozwolil kase wywalic na 300/2.8 i nie musze tu, jak niektorzy, plakac ze im zony zrzedza i co oni maja zrobic
| moronica napisał/a: | | tylko czy d90 dotrwa do tego czasu | Musisz mniej zdjęć robić i kto wie...
jaad75, tak, najlepiej w ogole przestane, wtedy dylemat wyboru korpusu mam z glowy
moronica,
Jak nie będzie w tej dekadzie D400 to D300/s/, albo D600, jak będziesz taka niecierpliwa.
alez ja jestem bardzo cierpliwa, korpusu i tak nie planuje zmieniac przed 2013 wiec niech Nikon sobie dlubie w tym d400 ile chce
no dobra panowie, ide spac zamiast tu offtopowac pod nieobecnosc modow, dobranoc
| moronica napisał/a: | | jaad75, tak, najlepiej w ogole przestane, wtedy dylemat wyboru korpusu mam z glowy | To jest myśl. I do tego łatwiej będzie Ci oszczędzać...
jaad75, oszczedzanie dla oszczedzania to jak wybor dla wyboru
moronica, ale wtedy przynajmniej wybór staje się potencjalnie bliższym urzeczywistnienia...
Nie chodzi o to żeby złapać króliczka...
sigmiarz - Wto 22 Maj, 2012
jak z d90 to tylko na d900
MM - Wto 22 Maj, 2012
Tak sobie patrzę... Ten Pentax to może i fajne aparaty robi, tylko co z tego. Dla mnie nie będzie istnieć do momentu dostępności fajnego zestawu różnych długich tele podpartych szybką serią i dokładnym AF-em. Chętnie bym coś takiego do roboty kupił a chwilowo mogę sobie tylko popatrzeć jakie to kolory korpusów powymyślali
Pentax to nie jest system do tele - mieli tego w przeszłości od cholery i świetnej jakości, ale najwyraźniej się nie sprzedawało, więc dali sobie spokój (no może z wyjątkiem tej nowej 560-tki) i jak dla mnie dobrze. Po co trwonić środki na produkowanie kosztownych, a przez to mocno niszowych szkieł?
Wujek_Pstrykacz - Wto 22 Maj, 2012
Bo Pentax to aparat dla wszelkiej maści ekscentryków, MM, do ciężkiej roboty to tylko Canon i Nikon. Sony zaś dla gadżeciarzy
| Wujek_Pstrykacz napisał/a: | | do ciężkiej roboty to tylko Canon i Nikon | A Hasselblad? Albo choćby Leica?...
Tak, Hasselblad, najczęściej je widać na stadionach za bramkami
Aszex - Wto 22 Maj, 2012
| jaad75 napisał/a: | | Hasselblad |
weź go w teren
hijax_pl - Wto 22 Maj, 2012
| Aszex napisał/a: | weź go w teren | Byś się zdziwił
Do statycznej fotografii krajobrazu, gdzie nie trzeba z tym ganiać, a przysłowiowy model nie ucieka - rewelacja
| Wujek_Pstrykacz napisał/a: | Tak, Hasselblad, najczęściej je widać na stadionach za bramkami | A ciężka robota, to tylko na stadionach?...
| hijax_pl napisał/a: | | Byś się zdziwił |
ja tak jak Wujek
btw, ponoć ma sporo stanieć, zwłaszcza entry-level
| Aszex napisał/a: | weź go w teren | Są tacy, co biorą. A takiego 645D to nawet często...
| jaad75 napisał/a: | | A ciężka robota, to tylko na stadionach?... |
sporty motorowe lub jakiekolwiek inne
jaad75, | jaad75 napisał/a: | | Po co trwonić środki na produkowanie kosztownych, a przez to mocno niszowych szkieł? |
| jaad75 napisał/a: | | Nie chcę też by Pentax rozdrabniał się i tworzył dodatkowe szkła pod FF - chcę by skupił się na APS-C. FF jest całkowicie zbędny w ofercie tej firmy i drażni mnie marnowanie środków na ten cel. |
-Coś ty taki oszczędny za Pentaksa?
Boisz się o przyszłość swojego systemu?
Nie tylko, ale to naczęściej widziane przykłady, choćby tylko w TV.
| Aszex napisał/a: | sporty motorowe lub jakiekolwiek inne | Wyłącznie? | dcs napisał/a: | -Coś ty taki oszczędny za Pentaksa?
Boisz się o przyszłość swojego systemu? | Wolę, żeby skupili się na szkłach które mnie interesują, albo przynajmniej dobrze się sprzedają.
[ Dodano: Wto 22 Maj, 2012 11:07 ]
| Wujek_Pstrykacz napisał/a: | Nie tylko, ale to naczęściej widziane przykłady, choćby tylko w TV. | No skoro w TV...
jaad75, k5 może służyć za młotek
| jaad75 napisał/a: | Wujek_Pstrykacz napisał/a:
No skoro w TV... |
Nie skoro, ale między innymi
Wujek_Pstrykacz,
A widziałeś harówę na FTV: "top fashion industry's photographers shooting glamorous models in exotic locations around the world, celebrities, calendar shoots, editorials and catalogues."
Nie widziałem, temat jest mi obcy
Ale za to widziałem harówkę na porannej fotografii toków cietrzewi. Ten temat jest bliższy memu sercu
I co dziwne, widziałem tam Pentaxa K5 z 600/4. Tylko, że dzięki niemu cietrzewie zwiały jak zawarczał AF
kozidron - Wto 22 Maj, 2012
| jaad75 napisał/a: | dcs napisał/a:
matryce będą rosnąć, czy tego chcesz czy nie, produkcja FF pentaxa jest nieunikniona, chyba że znowu sobie strzeli w nogę
kozidron, ja wiem, co jest nieuniknione, tylko, że wcale mnie to nie cieszy...
A może pojawi się jakaś przełomowa technologia, która będzie bardzo droga w produkcji w pełnoklatkowej wielkości...
komor - Wto 22 Maj, 2012
dcs, czyli w zasadzie powrót do początków cyfrowej fotografii, tak?
Wyścig rozpocząłby się od nowa. Tylko jego uczestnicy mogą nie być zainteresowani.
| dcs napisał/a: | | A może pojawi się jakaś przełomowa technologia, która będzie bardzo droga w produkcji w pełnoklatkowej wielkości... | Już jest - czarny krzem...
a co to za cholera? potomek vadera?
Aszex, wygooglaj sobie...
| Cytat: | | Wszystkim, którzy już cieszą się z takiego rozwiązania, przypominamy, że na szum, jaki widzimy na fotografiach, składa się nie tylko matryca, ale również cała elektronika, która ma za zadanie przetworzenie sygnału pochodzącego z elementu światłoczułego. Z tego powodu trudno mówić o drastycznym wzroście czułości. Jednak każdy wzrost czułości ISO oraz zmiejszenie się szumów będzie dużym postepem. |
http://www.swiatobrazu.pl..._fotografi.html
Raczej ewolucja
| Aszex napisał/a: | Raczej ewolucja |
Ciekawe, czy taka jak zejście z drzewa i utrata większości owłosienia?
Aszex, byś sobie ten cytat odpuścił...
Przypominam, że mamy rok nie 2008 a 2012 (w elektronice to cała era) i dziś już wiemy, że elektronika może być tak skonstruowana, żeby nie generowała szumu (matryca IMX071 ma szum na poziomie pół bita)
| hijax_pl napisał/a: | | Przypominam, że mamy rok nie 2008 a 2012 |
No cóż. A tych matryc dalej brak mimo że są. Chyba, że producenci chcą wycisnąć max z obecnej technologii.
http://sionyx.com/imaging-applications/security/
[ Dodano: Wto 22 Maj, 2012 12:50 ]
http://www.tomshardware.c...news-37574.html
| Aszex napisał/a: | | No cóż. A tych matryc dalej brak mimo że są. | A potrzebujesz więcej już dziś? Nie mówimy o specjalizowanych zastosowaniach ale popularnej fotografii - tu matryce osiągnęły wymagany poziom już dawno.
Moim zdaniem ewolucja skończy się wtedy, gdy przy nocnej fotografii matryca dorówna ludzkiemu oku.
| Aszex napisał/a: | | gdy przy nocnej fotografii matryca dorówna ludzkiemu oku. | Czyli nie chcesz widzieć koloru?
Jeśli jest na tyle jasno, że widzisz fakturę to i kolor też.
| Aszex napisał/a: | | Moim zdaniem ewolucja skończy się wtedy, gdy przy nocnej fotografii matryca dorówna ludzkiemu oku. | Już teraz można (przy całkiem krótkich czasach) pokazać na zdjęciach więcej niż widzi ludzkie oko w nocy...
Zdjęcia z ręki, z małym zaszumieniem?
| jaad75 napisał/a: | | pokazać na zdjęciach więcej niż widzi ludzkie oko w nocy... | Otóż to... Już myślałem, że Aszexowi chodzi o to, by obraz z aparatu był ciemno-niebieski, o małym kontraście, z utratą ostrości w środku kadru itp itd
| Aszex napisał/a: | Zdjęcia z ręki, z małym zaszumieniem? | Tak.
Przykład?
Przykład czego? W obecnych czasach ISO1600 jest w przypadku dobrych matryc mało zaszumione, a ISO6400 używalne bez większych problemów (w przypadku np D3s używać można nawet 12800). ISO1600 przy f/2 i czasach rzędu 1/60 - 1/15s to między 2, a 4EV, które odbierasz jako półmrok (np. światełka choinkowe dają zwykle okolice 4EV), podwyższając ISO do 6400 lądujesz w okolicach 0-2EV, a to już naprawdę ciemno i oko musi się do takich warunków jakiś czas adaptować, żeby znośnie widzieć.
Miałem na myśli już widzenie już po adaptacji i to tej dłuższej. Fajnie, że to już jest i za parę lat wejdzie w segment canona xxx, chyba.
| Aszex napisał/a: | | Miałem na myśli już widzenie już po adaptacji i to tej dłuższej | Czyli jednak bez koloru...
forum.okulistyczne.pl ?
| hijax_pl napisał/a: | | Czyli jednak bez koloru... |
tyle że ja go widzę...
dcs
http://tiny.pl/hpst3
Euzebiusz - Wto 22 Maj, 2012
| Wujek_Pstrykacz napisał/a: | | Bo Pentax to aparat dla wszelkiej maści ekscentryków, MM, do ciężkiej roboty to tylko Canon i Nikon. |
Dobrze, że jestem ekscentrykiem i nie muszę ciężko pracować
PS. Swoją drogą to ustawienie aparatu za bramką i wyzwalanie pilotem gdy zbliża się piłka to chyba nie taka znów katorga?
Chociaż już łapanie teleobiektywem smarkających na trawę spoconych facetów do przyjemności chyba nie należy...
Chociaż... nie wiem. Może.
jaad75 - Sro 23 Maj, 2012
No i już wiadomo, że mikrokalibracja będzie w pełni funkcjonalna (z pamięcią dla poszczególnych szkieł):
piżej74 - Czw 24 Maj, 2012
Jeżeli przyjmiemy, że ekscentrycy to tacy, którzy nie fotografują w ciężkich warunkach, to ta pokrętna logika może mieć sens.
BTW: Rozumiem, że testowałeś już nowy system AF w K-30?
sigmiarz - Czw 24 Maj, 2012
w tej cenie nie kupisz niczego nacona co by się nadawało do fotografowania w ciężkich warunkach
jaad75 - Wto 29 Maj, 2012
Jednak będzie więcej kolorów - ciekawe, czy wszędzie, czy tylko w Japonii...
dcs - Wto 29 Maj, 2012
| jaad75 napisał/a: | | Jednak będzie więcej kolorów... |
To ostatecznie wykończy konkurencję.
Aszex - Wto 29 Maj, 2012
jaad75, a który oprócz czarnego podoba Ci się najbardziej?
| dcs napisał/a: | | To ostatecznie wykończy konkurencję. | W Japonii, to nawet bardzo prawdopodobne...
| Aszex napisał/a: | jaad75, a który oprócz czarnego podoba Ci się najbardziej? | Biały może być. Podobałby mi się srebrny, gdyby nie był plastikowy. Obawiam się jednak, że ze względu na fakturę kolorowych plastików, czarny będzie sprawiał wrażenie sprzętu o klasę wyższego, tak jak i w przypadku poprzednich kolorowych modeli.
a w rękach kobiety ten bordowy (czyt. czerwony)
Usjwo - Wto 29 Maj, 2012
| jaad75 napisał/a: | | Jednak będzie więcej kolorów - |
jarmark cudow normalnie...
krzys13k - Wto 29 Maj, 2012
Jestem zawiedziony brakiem różowego.
sigmiarz - Sro 30 Maj, 2012
można wybrać mat i błyszczący
http://www.pentax.jp/japa...olor/index.html
cosin - Pią 01 Cze, 2012
kurcze właśnie chciałem kupić k-r'a lub dociułać do k5, takie k30 byłoby idealne. Ciekawe kiedy będe miał go w dystrybucji... i za ile rzecz jasna
lotofag - Pią 01 Cze, 2012
IMHO bierz K-5 póki jeszcze są jeśli już się zdecydowałeś na Pentaksa. Nawet jeśli kilka "bajerów" w K-30 jest "nowszej generacji", to nadal K-5 jest po prostu korpusem z wyższej półki z zaletami których w K-30 nie ma i nie będzie, a cena atrakcyjna...
k5 mam w magazynie jeden z 18-55wr więc w razie czego poczeka mimo wszystko jest ponad budżet, a nie do końca widzę zasadność dopłacania w moim przypadku.
jestem ciekaw jak się będzie miał k30 do planowanego C 650D
jaad75 - Pią 01 Cze, 2012
| cosin napisał/a: | | mimo wszystko jest ponad budżet, a nie do końca widzę zasadność dopłacania w moim przypadku. | Ale przecież na początek, one będą w niemal takiej samej cenie... | cosin napisał/a: | | jestem ciekaw jak się będzie miał k30 do planowanego C 650D | Ja myślę, że raczej będzie go należało porównywać z 70D...
cosin - Sob 02 Cze, 2012
| jaad75 napisał/a: | | Ja myślę, że raczej będzie go należało porównywać z 70D... |
ja porównuję te modele przez wzgląd na porównywalną (jak myślę) cenę.
jaad75 - Sob 02 Cze, 2012
| cosin napisał/a: | | ja porównuję te modele przez wzgląd na porównywalną (jak myślę) cenę. | Czyli K-5 porównasz z czym?
Tak się nie da. Zresztą zobaczymy, co Canon pokaże w 650D i w 70D, a Nikon w D5200 i D7100. Porównując jednak z obecnymi modelami, to póki co K-30 będzie konkurencją dla 60D raczej, niż 600D.
brysp - Nie 12 Sie, 2012 Temat postu: Grip Słyszał ktoś może czy do K30'stki będzie może battery grip, czy Pentax znów powtórzył swój błąd?
lotofag - Nie 12 Sie, 2012 Temat postu: Re: Grip Trzeba sprawdzić czy ma toto złącze do gripa, jesli nie to baj baj i kupuj K-5 póki jest
Róznica w cenie chyba nadal nie jest zbyt duża.
bodzio239 - Wto 14 Sie, 2012 Temat postu: Re: Grip Jeżeli Ktoś posiada i użytkuje , ewentualnie miał możliwość osobiście ocenić pracę autofokusa oraz przydatność wysokiego ISO to bardzo prosił bym o spostrzeżenia . Dla mnie jako dla amatora hobbysty wydaje się być idealną propozycją. W internecie można znaleźć wiele zdjęć i informacji , a nawet porównań (najwięcej oczywiście w języku królowej Elżbiety) , mimo to wolę ocenę uczestnika , czy powiedzmy sympatyka tego forum , a wiem , że zwolenników marki Pentax tutaj nie brakuje. Zły los sprawił , iż pozbyłem się bezpowrotnie w okolicznościach o , których nie będę tutaj pisał mojego zestawu D7000 + 17-50 S + 12-24 TO + 70-300T więc nieśmiało zaczynam myśleć o K-30
Plastikowość to dla mnie żadna wada , a sądząc po moim pięcioletnim niezniszczalnym Olku 590 UZ towarzyszu wędkarskich wypraw to nawet zaleta . Jeżeli K-30 jest zbudowany z podobnego tworzywa ze wstawkami ze stali nierdzewnej i do tego porządnie uszczelniony to daj mu Boże zdrowia. Jeżeli cena spadnie do 2500-2600 to kto wie……
dcs - Pon 17 Wrz, 2012
dxomark Pentax K-30 Review
http://www.dxomark.com/in...-30/Measurement
